December build available for download from OneDrive
https://skydrive.live.com/redir?resid=E5E8A7DE0FA794BC!68359
(for next uploads, which one do you recommend: Box sync, Google Drive, MEGA, or OneDrive?)
Features:
1. Only
1.2 GB footprint on C: drive (54 GB free out of 55.2 GB C: drive on the 64 GB model) (excluding hibernation and pagefile)
2. August, September, October, November, and
December update rollups slipstreamed
3.
Surface Pro 3 specific updates included (KB2978002, KB2969817)
4.
Bloat free: (Microsoft devices are shipped bloat-free? Think again)
- Only
6 metro apps included (Camera, IE, OneDrive, PC Settings, Photos, Store). The rest can be downloaded from Store
Trial Office removed
Speech data removed (who uses that anyway?)
5.
Pen Pairing OOBE appears and working
6. Languages included:
Dutch, English, German, French. Since it is Windows 8 Pro, you can download any other language later.
7.
WinRE from vanilla Windows, 200 MB saving (working so far, please report if something wrong happened)
I have been using this build for 2 days, as well as the previous, similar build for a week. No issues experienced from my side.
This *might* also work on the Surface Pro 2 since they have similar components. Not tested.
How to install:
0. Get a keyboard and USB hub (Type Cover might also work, but I don't have one to test)
1. Download and extract the package
2. Set up the ISO image on a CD or USB stick.
- If you use Rufus, set it on "MBR for UEFI computer" (only for the USB stick, the Surface will be set up as GPT)
3. Boot it on the Surface
4. Enter
cd /d D:\scripts
5. Enter
diskpart /s part43.txt (part43.txt means the recovery partition is 4300MB. I tried 4200MB, it didn't work)
6. Enter
applywim D:\Images\install.wim D:\Images\winre.wim
7. You can repeat the step #6 just to be sure
8. Reboot, unplug the USB stick.
