Surface pro 3 Password
I was basically asking how to disable to login on standby. Because I don't think I do.
Easiest way I know is to type screen saver in search. Go to screen saver settings and see if it is set to ask for a password when it comes on. Not saying that's where the problem is, just asking that you check it.
Unfortunately the only setting is "on login display log on screen"
you do have deactivated this one?
