OP Y yoka New Member Jan 20, 2016 #13 sharpcolorado said: @yoka (OP) I see you have posted here: hi guys , for the surface overheating problem. please remove your HP printer and scanner APP Does this mean your problem is solved? Click to expand... yes , solved after removing the HP app
sharpuser Administrator Staff member Jan 20, 2016 #15 @yoka, You may have had some other program running which does not cooperate well with the HP apps. So the problem may not be the HP apps, but instead, your overall installation.
