Surface Pro 3 Accessories
Here are some pictures:
With SP3+Type Cover (+pen in loop):
With SP3+Type Cover + Logitech Pointer + SP3 Charger + 3x USB 3.0, Ethernet Adapter:
With SP3+Type Cover + SP3 Charger:
"Normal" (SP3+Type Cover with pen in the loop are fitting perfectly!):
Thanks for the pictures. Looks very nice. Mine should be here tomorrow.
PS Are you pleased with the HooToo Ethernet Adapter? Do you have to install any additional drivers or does it work with the standard one from Microsoft?
Before I first plugged it in I connected 3 USB Sticks and a 100mbit connection. Then I connected it, it installed some drivers and everything worked fine. As I don't own a 100mbit+ connection I can't tell if 1gbit would work.
cool skins for the Microsoft surface pro 3 ! got my pink antibacterial matte skin and I love it .. it protects my device from scratches and gives it a cool new look .. also, I used promo code KITTY and got 10% off my order (=
Why not get a tempered glass screen protector? Works perfect with the pen while normal screen protector meh
Any recommendations?
MIME seems to be popular. It is discussed with postive remarks in this thread: http://www.surfaceforums.net/threads/screen-protector-for-sp3.9250/page-2#post-76452
Appears sold out on their site at the moment: http://mimeusa.com/product/surface-pro-3-ghost-glass-screen-protector/
Also, sharpcolorado seems to like the Phantom Glass product, which he ordered, but never followed up with any comments about it (that I'm aware of). He may chime in if he spots this reply. He mentioned it here: http://www.surfaceforums.net/threads/screen-protector-for-sp3.9250/#post-75180
Personally, I stopped using screen protectors since getting products with Gorilla Glass. I may regret that one day, but so far, I've not suffered any screen damage on those products.
Anyone have suggestions for a good external keyboard and speakers. I'll looking to overhaul most of my current setup. Listed below are the items that are on my wish list:
Keyboard: Logitech K810 Bluetooth keyboard. (I prefer smaller sized keyboards)
Speakers: AudioEngine A2, or Kanto YU2, or Bose Companion 20 speakers.
Anyone has experience with these products or suggestions of products they like.
@Kif, I use an HP BT keyboard (small) that I like. Found it as Best Buy, but you can order it off the web too. I think it's called a K4000, but don't depend on that (the actual name isn't on the keyboard). Model number is SK-9071
