Surface Pro 2 - died
andrew.zaitsev
In the evening turned off, and in the morningit just will not turn on.This happened after installing the latest updates. :( There is no official support in Russia. The pain of my heart.
Not sure if you tried, but you can hold down the power button to force it to turn off (perhaps it is working and just won't wake up) and see if it turns on again. Or try charging it a few hours to make sure it didn't drain over night with those updates.
try this, hold the power + volume down and hold for 20-30 seconds until you feel it vibrate and it should restart
