Recently had all updates installed on my SP4, but show in Device Manager that the device will not start (Code 10).
In device manager it previously said something like, restart needed, in the Surface Management Engine properties/status page.
I manually restarted (including cold boots), but no change. The SP4 seems to be working fine otherwise - is there a way to check what things are not working, because the Surface Management Engine has not started?
anyone else seen this or know what to do to fix this?
Jeff
Jeff
