I think it would be good to disable the button only in certain apps. In OneNote I still catch it sometimes.
Turn your SP3 and put the bezel with the button towards the north. You wont catch it anymore.
Or you can just swipe from the rightWhat would be good is if it would allow you to Disable the Home button and reassign the Pen top button to home. Then when you go to do notes (in say Onenote) you can disable the home button and since you won't be using the top button to go to Onenote you can use it to go home. Perfect!
Oh dear...
So MS has seen a need for flexibility with its Windows button, and designed (a very elegant looking) Surface Hub to include an "on-off" switch.
How many hours of planning, coding, writing, and disseminating went into this effort?
It simply doesn't work.
This is embarrassingly tragic. In some ways, even insulting.
I hope there is a fix for this quickly, to avoid more catcalls from the antiMS crowd
