Surface Go 3 USB-C Charging Puzzle
Lobalobo
The USB-C port of my Surface Go 3 will charge the device when plugged into a wall outlet through a 100W, "15V=3A" wall charger.
Using the same cable, the device will not charge (though it did once) when attached to a 63W Eggtronic battery with the following Voltage specifications:
As I mentioned, this battery worked once to charge the Go 3, but now will not even though it seems (at least to me) to meet these minimum specifications:
  • Surface Go models: Require 30 W PD (15 V / 2 A) or 45 W PD (15 V / 3 A)
What am I missing? Thanks in advance.
The minimum specifications you provided are from a data sheet by a company that sells a Surface Connect to USB-C charging cable.
Fast charging via the USB-C port has a different requirement, as the Surface Go 3 (and other Surface devices) will request 20V from a PD power source. As a result, Microsoft recommends a USB Type-C PD charger rated at 60W or higher. While your Eggtronic Laptop Power Bank will furnish 20V, the 45W rating for the USB-C port may be a little too low for comfort and may provide inconsistent results depending on the state of charge of both devices.
Although you don't mention the brand and model of the 100W charger at the beginning of your thread, given its 100W maximum rating, I would think it should have the capability to provide 20V / 5A.
Thanks so much for such an informative and quick response. Hope you don't mind a couple of quick follow-up questions: First, the Eggtronic Power Bank is rated at 63W, so I'm not sure I quite understand how the "45W rating for the USB-C port may be a little too low for comfort." Is it that 63W , 20V of the Eggtronic is Power Bank is too close to the minimum on both measures, leading to inconsistent results? In any case, do you know of a small Power Bank that has high enough specs to work reliably? The issue matters to me because when I travel with just the Surface Go 3 it would be a help if I didn't need to also carry a devoted charger, using the Power Bank for both phone and tablet. Thanks.
