trident777
- Joined
- Oct 21, 2016
- Messages
- 18
- Points
- 1
- My Device
- SPro4
I just acquired a Surface Dock to use with my SP4 and dual 1080p monitor setup. I was really apprehensive reading all the problems but i'm happy to report that everything works perfectly... both my external monitors are running at 1080p/59hz and the desktop extends to my SP4 screen as well for the 3rd monitor running at 60Hz. I've also connected a Toshiba 1TB HDD that works perfectly as well as Ethernet (unfortunately my router is only Fast Ethernet 10/100, will have to upgrade to Gigabit one of these days! but good to know that the dock is Gigabit). I checked restart and sleep and that works fine as well.
I am using this mini displayport to HDMI adapter:
PPA Mini DisplayPort to HDMI Adapter
Question - I am planning to use my SP4 as my desktop machine 75% and as a laptop 25%, so this setup is going to be plugged in 24/7 for many days on end.
- I am assuming there are no reliability issues with running the dock continuously?
- what is the effect on the SP4 battery using it this way, i.e. continuously plugged in?
