BullfrogJG
After lots of online and in-store searching, I finally narrowed my search for a carrying bag down to these three:
Targus EcoSmart Mini Messenger Case
Advance Ultrabook Briefcase
CaseCrown Horizontal Messenger Bag
My preference was the CaseCrown followed by the Targus, but I ended up getting the CaseCrown bag. It comes in three colours: black, brown, and magenta. Also, it comes in either a horizontal and vertical orientation. I went for the horizontal one in brown and got it in the mail a couple of days ago. My first reaction is that it's outstanding. Looks great and has really good functionality.
The case is nylon and has a bit of a shimmer to it and the interior is a bright orange. There are many pockets on it for putting your stuff including one on the outside of the cover and a quick access pocket on the back. There is a small pocket on each side, though they're pretty tight and you wouldn't get much more than a few pencils in them (definitely can't put in a water bottle.) Open it up and there's a pocket on the inside of the cover that looks like it's made for a passport and on the outside face there is a slip pocket and a zip-up organizer pocket with space for three pens and some cards and a clip for keys (and they give you a nice keychain). Inside, there's two main compartment2; one is padded for the Surface and the other is non-padded and has a divider, good for notepad, small book, or your surface accessories like mouse, charger, and displayport adapters. The Surface compartment is perfectly sized; the surface slips in easily but it isn't loose (at least side to side, there's a bit of room at the top though it can be cinched down with the elastic strap with velcro). I was able to slip the surface in with a tiny usb receiver sticking out and the type cover 2 on and it's a good fit. There is a shoulder strap, but no handle for carrying it with your hand.
All in all, I'm very happy with the purchase and think the price was right. I do a bit of traveling for work so it was important that the case could carry more than just carry the Surface, so having all the extra pockets is helpful. It's nice because it's not a bulky case at all and is clearly designed for the Surface based on the perfect fit.
Front of case (kind of a brownish grey, hard to describe the colour), showing front zip-up pocket:
Front with Surface on top for size comparison:
Open view showing passport pocket, two front pockets, and keychain:
Top view showing organizer pocket:
Top view with Surface in padded compartment:
