clawlesskurt
- Joined
- Apr 5, 2021
- Messages
- 1
- Points
- 1
- My Device
- Other
I have run into an issue with a new Surface Book 3 where I am trying to run 2 external monitors (Dell SE2719H), but one of them does not light up. I am using a Surface Dock 2 with USB-C to HDMI cables to send signal to the monitors. Windows detects the monitor as connected, and when I remote into the machine using my remote management software I am able to see the display signal, but the monitor never wakes up. This monitor works when connected to a Surface Pro 7 using the same cables. I have also tried using different monitors with this Surface Book 3 with the Dock 2, and still the second external device does not light up.
I am using the current firmware and drivers from Microsoft. Windows is completely updated on version 20H2. The surface display is running at 3000x2000 with the external monitors set to 1920x1080. I have verified that refresh rates are set to 60Hz, same as the native refresh rate of the Dell monitors. Any guidance in how to get this issue fixed would be appreciated.
