Mean Spitfire
Hi, The last time I used it was in 2018. I then bought a laptop and stopped using the Surface. I recharged it every 6 months or so. Now I want to resume using it, but it came up with an error, 0xc0000185, telling me that I need an install media. So I put my Media Creation Tool (used on my PC, Win 10/64 PRO) in the USB port, and rebooted using Vol - with the power button simultaneously. Now, I got a bit farther. It asks me to choose my keyboard. But I can't go any farther. I can't go down to "See more keyboard layouts" because I don't have the MS Surface KB that I bought at the same time I bought the Surface 3. That MS KB failed just after the warranty expired on it. I can't even select the highlighted United Kingdom KB. So I now have a Bluetooth KB (bought after the MS KB died) which needs to be paired, which is not possible since the Surface isn't up yet. The MS pen is also useless. And not being in tablet mode, I can't use my finger to select anything on the screen... Pickle! I'm in a pickle! Any solution??? OR should I make a new MCT for the Surface? I can't remember, but it may use Win 10/64 Home, as opposed to Pro for my PC. I could then make a "Home" MCT. Please advise. Thanks very much, John
