I do not have any pending reboots. I think I'm going to try a reset.Do you have a pending Reboot from any Updates?
You may also consider doing a Reset from the Update and Recovery Settings...
Oh I actually do have updates waiting to be installed. I'm going to install those and then try the resource monitor. Thank you very much!Check windows update is it downloading updates?
Also if you launch Task Manager then go to performance tab you can launch Resource Monitor and the disk section should indicate what file or files are being written to by what - sort by write and expand the file column under Disk Activity.
Typically most Update Packages are cleaned after they are Applied, this could also be why Disk Cleanup wasn't being effective...Oh I actually do have updates waiting to be installed. I'm going to install those and then try the resource monitor. Thank you very much!
Ok. I am currently updating three updates that had failed before. I wonder if that was causing the problemTypically most Update Packages are cleaned after they are Applied, this could also be why Disk Cleanup wasn't being effective...
We'll see after they are appliedOk. I am currently updating three updates that had failed before. I wonder if that was causing the problem
So the updates installed and I have been testing whether the storage will go down. So far it has been ok but if the disk drive starts filling up again I think i am going to do a reset. Thank you for all of your help and support.We'll see after they are applied![]()
That is cool thanks! I was mostly an apple guy and was hesitant to switch over to surface. I didn't realize how awesome these tablets were and how great they were for productivity!Btw the S2 is a great device! While I had it I totally luved it and used it all the time and everywhere, I suggest you install splashtop so you can remotely use your desktop from your S2... it's just like using a full OS on your S2!
