Hello!
Is it possible with usb3.0 unpowered port connect the Plugable Hub usb3.0 and extend SP3 screen in multiple monitors?
See this video to understand what I'd like:
You should be aware, that I believe that the Pluggable stuff makes you install software to use their devices. That software I think renders the video, and therefore runs your CPU usage up like 20%.
Just an FYI, someone correct me if I'm wrong.
Malbertoo, DisplayLink CPU utilization has improved quite a bit with their 7.6 drivers. 20% usage is not typical and is far less in most cases. Windows update will grab the drivers automatically once you plug in the dock so you don't really need anything from pluggable. Pluggable has *great* support based in Bellevue, WA and will help you with any technical issues though.
