Sorry another question surface pro 3 pen compatible surface pro 6
Right I upgraded to surface 6 from surface pro 3
I didn't use the pen much so didn't see point spending extra money on pen , thought could use old pen from surface pro 3
managed to connect the pen using Bluetooth the button ontop works and like screen shots when pressed
but when I try to draw right the pen nib dosent do nothing when drawn on screen
is it possible to make it work
Cheers
Cheers
Remove the Quad-A battery and put it back in - if that doesn't work the battery may be dead. I typically get my Quad-A batteries from Amazon...
