If you get a dry install, more than likely you'll have dust under the protector. Wet install, even when there is dust in the solution, will dry flat and get rid of all air bubbles, if you follow directions. I haven't had any dust under the protector with all of my wet installs. If you do a dry install, do it the bathroom and run the shower hot for a few minutes to steam up. The steam captures most of the dust particles and you should have an easier install.
Is a screen protector really necessary? I dont baby my device and it has no scratches. The smudging does annoy me though--do the protectors hlp w tht?
... The smudging does annoy me though--do the protectors hlp w tht?
Just picked up the Zaag Glass cover from BB last night. Weary about opening it and putting it on, as its $55. See that you have the same cover, what are you opinions on it now that you've had it a while? How is the pen input, is it different at all. Like the range, responsiveness, ect. How is the glare from sunlight? Artificial light? Any reduction in screen quality, like brightness, clearness, or colors and vibrancy?The glass protector helps tremendously with fingerprints, grime, dirt, smudges. I don't quite understand how that works, but it does. The Surface screen is nice and smooth, but not as smooth as this Zagg glass, and the Zagg remains cleaner. This is a must for me, because some of my use is outdoors, and some in various offices with those infernal fluorescent fixtures everywhere.
