I updated to the SP3 from the SP1 and notice a few things that were not present on the SP1 and would liker to know if these are supposed to be this way.
1. When using the pen to take notes the screen seems to flex a little bit when the tip of the pen presses against the screen. On my SP1 it was very solid. Could this be related to making the device thinner? I would think that since everything is packed inside so tightly it wouldn't flex.
2. The metal frame around the perimeter of the screen sits up above the screen just enough that it creates a lip at certain areas (left and right sides). The top of the screen where the camera is located is flush.
3. When using the pen to take notes in OneNote the first stroke or letter doesn't appear to register sometimes. The SP3 is less than a week old so the pen batteries are still new. When this happens it throws me off and I usually have to erase the second stroke and start over. Also sometimes the ink will show up at a different location then where I'm writing. Again never had this problem on the SP1, only corner and edge tracking issues.
Thanks
Thanks
