All cell phones work like that.
If you have an Android device you'd could try and find charging dataligging apps in the Play Store.
wanted to apologize for not replying till now.. had to go out of town for a medical emergency. Once I'm aloud to go home I'll run the tests... if you find anymore info till then please keep me informed.. thanks
Hi! I got my Surface Book 2 15" 1060 some days ago and tried some gaming to see how it performs. Unfortunately I had MASSIVE battery drain (like 10% in 15min). I saw this thread by searching on google and tried to run BatteryInfoView (thanks for the hint!).
This is the result:
Imgur
After running the application for some minutes it seems the charging won't go above 20Watt in total. That is pretty low, isn't it?
It feels like the power adapter doesn't work or is broken and doesn't deliver the energy by far (especially in gaming).
Anything I can do?
Thanks!
So... I'm already back and I had the possiblity to check the battery consumption. The battery consumption when not-gaming seems to be normal. But now I'm charging the battery at around 50% and I still don't get more than 20 Watt in total. I also tried gaming with battery-only and after half an hour my base battery went down from 100% to 35%. Doesn't seem to be a normal behaviour - so I probably have to exchange my notebook + ac-adapter. Damnit
I asked the Program Manager in charge of the Surface Book 2 about this week and here is what is happening (it is by design). The SB2 15" Thermals were actually quite a bit better than they anticipated and allows the CPU/GPU to run at a much higher wattage so the Power Supply will give the CPU/GPU the power without throttling rather than the batteries up to a point - it will only allow the battery to go down to ~30% and then it will start charging the batteries by slightly throttling the CPU/GPU. Their tests show that the throttling would be the equivalent of moving from 60fps to ~54fps....
Hope that clears that up....
