RémiM
Hello there !
look, I am also a teacher. I work at University and use my SP3 all the time. For my teaching (OneNote plugged to projector and other things) and for my research (I run physics modeling softwares, C++ compilers, Latex, Gnuplot and a bunch of other things). Spotify is running in the background all the time. My SP3 is never resting.
I am a devoted Linux guy and surprisingly I left my Linux computer a little bit since I got the SP3.
I stopped all the indexing options. I know where I put my shit, I dont need them. And so far so good. Most of the time I run without any antivirus or firewall, except when I am using a public network.
My SP3 idles at 8-9% of RAM use, never gets hot (or one a while if something running hard), and is always there for me. I also use it a lot in my couch and in my bed for Netflix and stupid web browsing.
To be honnest with you, I am still babysitting it and I also feel a bit worry using it a lot. But you know what ? I didn't spend 1500$ not to use it. I know I will buy the next iteration, or the one after, and I am sure this beautiful SP3 will still be in top shape.
So dont worry. Keep doing what you do. Your SP3 was designed for it. It's made to handle hours and hours of work. And most of the time stuffs are designed for situations that you will never reach in your normal daily use.
I know what it is to spend a lot of money on something and to be worried to brake it or using it too much. But it has to remain a pleasure and not constraint.
And if all that is not enough, I suggest you subscribe to the Complete care plan.
Bye
Bye
