machistmo
Actually, there are several things we can assume from the OP's post and subsequent posts such that it's not too early to make a recommendation:
OP went to an actual MS store to try out units. I'm assuming MS store only because the salesperson was knowledgeable enough to know a certain app was coming down the pike for WinRT (assuming he's right), and I don't expect anyone from other brick-n-mortars to know nearly as much. Even if it wasn't an MS store, the store would have other Windows devices available for demo, and the OP still came away with questions specifically about the Surface. Given the hands-on, we know the form factor isn't too small for OP and such and there is enough of an attraction to ask the use case questions.
OP was smart enough to give actual and specific use case examples for performance questions. The specific use case question is easily tested with the proper sample, and OP went to the store to actually demo it again in person using a sample. This is way more testing for a use case than in most circumstances. The test results from other users indicate even the first gen RT is sufficient for OP.
The low-maintenance nature of Windows RT (malware) is a big plus for a transitioning Mac user who doesn't want to deal with that maintenance in full Windows. OP expressed preference for Surface RT over Pro's form factor due to weight.
The primary issues revolve around lack of two specific functions, whether as apps or bundled into something else---SFTP as a separate app or in a file manager or something, and Adobe PS Touch. Supposedly the latter is coming, and I haven't found a good "regular use" app for the former (though I use side-loaded PuTTY myself).
By the above, we can say that Surface RT would be fine, and the OP should wait for the 2nd gens for an even better match to the conclusions we drew from performance-testing RT v1. The only draw for 1st gens is price cutting; there may be a bigger price cut in store, but who knows.
I would still not suggest anyone buy anything generation 1 when generation 2 is just about to drop. Period. OP - WAIT - don't listen to fanbois.... Wait, for the love of God, Wait. Don't get an RT device, seriously, don't listen to this guy, avoid the RT. You will be able to get a new Intel Powered full blown windows tablet CHEAP soon. Don't go for a tegra4 based unit when very shortly you can get a nice intel based device running the full blown windows and install whatever you want.
Again, IT IS TOO SOON TO BE ABLE TO POINT TO ONE DEVICE, but of all of them, I would NEVER point to an RT. This guy is coming from the world of iPad, stuff that works with every app you could imagine available right now and you are pointing him to an RT? Seriously and with a long winded bloated bunch of BS reasons and assumptions as justification for your bias toward RT?
I mean its just mean. And if I ever suggested an RT device it would be the one running the SnapDragon chip not the Tegra4.
Comparing the iPad3 to the RT ought to be illegal. There is no comparison here. This guy is going to be seriously bummed if he does follow your advice. I think we can both guess that the post was a troll post designed to lead to the RT being the suggested device, but I still can't and WON'T do that.
*** For the record I have owned each device.. The RT1, The SP1, the iPad3 and 4 and used and staged several other tablets. Everything I say is from experience, use and is of course my personal opinion. One taken from actually using all of the devices in questions as a result of OWNING them. Albeit my opinions are unpopular where the surface RT is concerned on these forums, but its the only place that is true.
