So you designed the case, then 3D printed?
Yep, going to make some more changes. Right now it blocks the usb and display ports on the side. I will have to at least open up acess to the usb.
I just ran a few tests using the firmware update from today and things look much worse. Firestrike dropped about 100 points and throttling has changed again, but for the worse as well.
My problem is, that the GPU Freq stays at 599MHz on AC. Why is that? I'm running Minecraft in Fullscreen Mode and i'm tring to achieve Higher FPS. I limited the CPU to 1.7 GHz, because i hoped that the GPU Freq will rise. Even with an additional fan it stays at 599 MHz. And my Surface Fan is allways running
Not to hijack this thread but I posted the low GPU speeds for i7's issue on the MS community forums here. Add you two cents and maybe we can get MS to respond or at least stealth fix the problem.
Sorry, totally forgot to mention it. Yes i have the i7 Model.
- edit -
I See, i haven't installed the Firmware 19.08.2014. I got my Sp3 today
Should I install it?
- edit -
I think you got the screenshots wrong, the top one show 600+ GPU Clock but you says it stays at 599MHz and the other shows 599MHz but you say it is a i5 with 600+ MHz![]()
