Iluminatus23
Do I have to turn on the energy states to get the script work?
Because now nothing happens.
I'm going to say yes to that but I'm using the guid.Do you have to call
powercfg.exe -setactive SCHEME_CURRENT
To apply the changes?
Yeah , I didn't see changes if I tried changing power plans by name which is why I did what I did and worked against CURRENT.The same here. I don't see the value being changed.
How can you check if the change was applied?Yeah , I didn't see changes if I tried changing power plans by name which is why I did what I did and worked against CURRENT.
Powercfg /query <GUID>How can you check if the change was applied?
