Update: CrystalDiskInfo - Software says my SSD is 96% healthy, so it means its all right with my HD....
No. That is VERY bad. It should be 100%. My 2 year old SSD on my desktop is 100% today, and I trash it with write.
Who know what cr@p you're syncing from a illegitimate copy of Windows... in good conscience my only advice a scrap your Surface and do a complete factory reset and not sync, I would also recommend that you bring your other machine into compliance...
Sorry to hear that you had a faulty SSD with your Surface Pro 2.
That's the problem with SSD's. If they work at 100%, it's completely fails, and usually you have no warnings of.
While an HDD, I best they are huge amount of faulty HDDs on the market, where they have 1 or several bad sectors, but as no one actually checks, it's all good.
Unless it's something major there is no performance drop visible. On an SSD, if you have a faulty chip, then you have strange issues.
I had an SSD once where, I installed Windows, everything was good, but every program I installed, despite installing successfully, would say "Invalid Win32 applications" by Windows when running them.
But after re-installing them 2-3 times they work.... for a moment... then stops working with invalid Win32 application bug. After further investigating, the SSD was faulty and was returned to the store for replacement. Now it works perfectly. I heard other storie where the SSD was faulty and leading to strange results, like where, when the RAM was filling up, program running on the back and idles where returned too, the system or program were crashed. It looked like faulty RAM, but nope. The pagefile was corrupted on the SSD. So as soon as Windows swamp things from RAM to the SSD, data was corrupted. So when it load it back from SSD to RAM, it was well all corrupted, and Windows wasn't able to detect the issue.
Hopefully your next Surface Pro 2 will be in good shape.
I had a couple of issues with my SP2 128 GB too.
- high CPU utilization when using my Micro SD card
- high disk utilization when using power save mode
- unable to install drivers (wifi, audio, Surface Cover Telemetry ...)
--> the SP2 got hot and laggy, even by web browsing
I have an unit with a 4300U CPU, so i did not want MS to replace it.
After searching the web i found the following instructions:
Systems Admin Guy | How to update Surface Pro 2 Recovery Image drivers
I followed all steps and i'm glad to say that all my issues are gone!!
Wifi, audi, and the issue with the Surface Cover Telemetry driver are fixed.
Power save mode works
no high CPU utilization when using my Micro SD card
I'm very happy.
It works for me so it should work for all others too.
Give it a try...
