Solved Power / Brightness ?Issue?
jnjroach, you're right, when I enabled Hyper-V which disables the Connected Standby, I get the guesstimates back....
I've disabled Hyper-V for now though...
For others that want to switch between the two:
To disable Hyper-V and restore Connected Standby functionality, use the following at the command line (cmd run in admin mode..):
bcdedit /set hypervisorlaunchtype off
To re-enable Hyper-V when you need it (and thus disable Connected Standby again):
bcdedit /set hypervisorlaunchtype auto
Your don't need to enable hyper v, just change this registry key:
HKLM\System\CurrentControlSet\Control\Power\CsEnabled (1->0) (change from 1 to 0 and restart)
