Now in that case, you right. Hope you get it figured out sooner than later.
Let me ask this, are you actually experiencing the battery draining faster after physically using it or you're only going by battery icon report? Which tends to not be accurate all the time. Because it does fluctuate and could be by a large amount.
Well, it appears that I have to retract my assertions about the battery life. Let me explain.
I started the battery test (or at least my informal, but real life version of it) at 7:00PM local time. At that time, I took the RT off the charger and the battery was at 100%. Since then I have been doing the following things:
Surfing the web with 4 tabs open all the time and moving from tab to tab continuously;
Mail app syncing 3 accounts all the time (after setting up the appropriate settings to each account - though I should mention that there is definitely something wrong with the Mail app vis-à-vis my Gmail account)
Reddit was open and I was flicking through various entries at regular intervals.
WiFi was always on, obviously
Bluetooth was on - though I was not using the BT mouse.
It is now 12:49AM - so about 5 hours 50 min and the battery - as per the battery icon - reports a charge level of 47%. This means if I continue using the Surface in the way that I have been using I should be able to get another 3 hours - minimum - of battery life, which gives me a grand total of about 8 hours 50 minutes of battery life. Let's round that off - on one side to 8 hours, which matches the claims made for the 1st Gen RT and on the other to 9 hours, which I think exceeds those claims. Either way, it is not too bad.
I should add that I did do the fix that was posted earlier even though I moved directly from 8.0 to 8.1GA. Could this have helped?
Thus, as things stand, I am quite satisfied.
The next thing to test (which I will probably do tomorrow night) is the battery life on connected standby.
I'll post an update accordingly.
