Port forwarding help needed
cemian
Hello,
Would anyone know any workaround to permit outgoing traffic from an internal IP that is being blocked by the router? I need to be able to use ports 21 and 587 but since I cannot log into my router to configure port forwarding or reset it at this time, I cannot remedy this issue. Seems to be a overly complex situation to an easy problem. Thanks!
you could try a VPN-Connection...but if those two ports are blocked VPN will probably also be blocked
