mitchellvii
If you ever decide to stop using OneDrive, don't make the mistake of clearing out your online OneDrive folders.  That's where your OneNote backups are kept.  Learned that the hard way.
I like it's simplicity, and to me it's as simple as being just a separate drive where OneDrive and GoogleDrive are much more tied in with specific applications, for example attachments in Gmail can appear in Google drive. I am using Onedrive more though since I have access to 1 TB from Office 365 subscription.I really like the layout of OneDrive.. the Windows layout it has. What do you like about Dropbox?
So you need to rethink how to use dropbox. Dropbox syncs a local copy of your files between all your PC's and keeps a copy on the dropbox server. So you would just work off the copy that's in the dropbox folder. What's cool is that you can add your dropbox folders to be listed in my documents \ pictures \ etc... Just right click it and select include in library.
Why use dropbox? Because they have the best API's and many applications natively plug into dropbox that don't plug into other cloud solutions. They also provide superior Apps for IOS, Andriod and other devices.
Another thing is that Dropbox keeps a history of your files so you can roll them back if something bad happens to the current version.
One benefit of Dropbox is with easily getting links for images you wish to embed in a forum. Just go to your Dropbox folder, right click the image and it will copy the image link for easy pasting. Don't believe OneDrive offers that.
So @malberttoo. For instance I have a folder called ExecutiveDecision where I keep all of my business files. Instead of having that on my hard drive and also in my Dropbox folder, you are saying I could achieve real time syncing by just letting it live in the Dropbox folder exclusively? I suppose a symbolic link would achieve the same result.
Yes exactly, no need for 2 locations, just let it live only in DB folder. It IS local on your machine, regardless of your connectivity state.
The owner of my company went the ultimate distance- he keeps literally EVERYTHING in his DB folder. All his programs point to their respective folders inside DB as their default save locations etc. In this way, if his laptop ever goes up in flames, he has no worries. He just finds whatever laptop he can get off the shelf (he travels a lot) and then would only have to re-download his DB to have his stuff.
