malberttoo
Now that would get to use Outlook in a heart-beat!!!!
Me too. That's at least 50% of the reason I'm in the Desktop...
Thanks for the write upHere is my 2 week update.
I've been exclusively using the SP3 since selling my late 2013 retina MacBook Pro. I do not miss the MacBook one bit, not even a little. The Sp3 does everything I want and more. Microsoft hit a grand slam with this in my opinion.
Out of curiosity, did you have a 13" or 15" Retina MacBook Pro?
I owned a mid 2012 15" Retina MacBook and have been interested in getting a Surface, I went to a PC World store here in Dublin today to check out the SP3 but I found it to be a lot smaller than I expected. I'm trying to decide between the new 15" Retina MacBook and the SP3.
The main pro points for the MacBook are the dedicated GPU, larger keyboard/trackpad and that it now comes with 16GB RAM, the main con is the price tag
I feel like it will be too small for me, but maybe I would get used to it? I would be mainly using it for Photoshop and I'm not sure there's enough screen real estate in comparison with the rMBP. The store was really busy since it's the launch weekend so maybe I'll try it again when they're less busy![]()
Thanks! I still love the fact that you can easily pick it up and go anywhere and have a full Windows PC, so I'll definitely consider that mobility factorWelcome to the forum!
Unless you have a desire to take advantage of the mobility of the SP3, it may indeed be the wrong machine for you.
You can of course connect the SP3 to external monitors. But if you already feel like it may be too small for you, then my advice to you would be to do a bit of research on this forum and the web, and see if the SP3 has any features that you really want, features that would overcome any unhappiness you might have about switching from a Mac.
Hope it helps!
I owned a mid 2012 15" Retina MacBook and have been thinking about getting a Surface. I went to a Curry's/PC World store here in Dublin today to check out the SP3 but I found the device to be a lot smaller than I expected. I'm trying to decide between the new 15" Retina MacBook and the SP3.
I feel like it will be too small for me, but maybe I would get used to it? I would be mainly using it for Photoshop and I'm not sure there's enough screen real estate in comparison with the rMBP. I wish there was a 15" Surface!
The store demo units were really busy since it's the launch weekend so maybe I'll try it again when they're less busy.![]()
I also really like the touch features and potential to draw on the screen in Photoshop. If I can, I may wait and see if a 15" Surface comes along in the future.
