SilverSurfaceSurfer
I've recently read (reddit:Surface problems?) an experience where Microsoft keep the holding because of warranty term not met.
Has anyone noticed that before?
Thats true ^^ but some light cosmetic damage from normal uses is not an argument or?It was a month old so it looked brand new (and the new one does too, over two years later). The guy in that post admitted his screen was all scratched up. There are plenty of idiots on reddit.
I think you will be fine. If your display has craters in it like the reddit guy then that's another matter. They fix the broken units and send them out as refubs. Would you be disappointed if you received your current unit as a replacement? If not then you are probably good.Thats true ^^ but some light cosmetic damage from normal uses is not an argument or?
