Micro USB/charging issue?
adambravo
Recently went to fire up my S3 at work only to discover the battery was dead--despite having disconnected it from an overnight charge (on the official charging unit) that morning. Went home and discovered that, even though the charging cord light was on (which I assumed meant 'charging'), it wasn't charging the battery. Had to wiggle the cord a bit before the charging actually began. Today, plugged it in--no problem. My brother (who works for Microsoft) thinks he's seen reports of this and it might be firmware related. Thoughts?
Might be the cable or some other weird micro USB issue. I connected my battery pack to charge, hours later still only showed one light. Disconnected and reconnected, still nothing after a couple more hours. Switched chargers, nothing. Then tried another cable and it started charging. Later to confirm the cable was bad I connected the charger to the battery pack and it worked. Thoughts... micro USB charging sucks.
My thought is that firmware is NOT where the issue lies. Most likely the port or the cable which would be hardware.
Agreed, probably an issue with the charger. You should have no issue getting Microsoft to replace it.
