Nathan Cotham
- Joined
- Dec 6, 2014
- Messages
- 4
- Points
- 1
I'm just wondering if anyone else is as concerned about this kickstand breaking as I am. I have only had this device for a few days, and I love everything about it, other than the noise that i just heard from the kickstand when i went to open it. I usually only use one hand to open the kickstand which kind of makes me think i should start using two. I'm afraid that using one is going to break it some day over the ton of extra use through opening it on only one side or something. Anyone experience the same paranoia when opening their kickstand?
