leeshor
Pretty much.So leeshor you are saying that leaving it plugged in throughout the whole time that someone is at his office or home (not away) is the best option for the battery, as long as you cycle it some times per month?
That's true. As I remember Microsoft has quote a much longer charging life cycle than is typical for Li-ion batteries. The technology is improving.That's more likely due to the build of the battery. Not all Li-ion have the same total cycles. I never trust the cycles quoted by the mfg.
Typical Batteries from IHVs and OEMs have 500-800 cycles over the lifetime of the device and Microsoft worked with their provider to get 1500-2200 cycles over the lifetime of the device, which is 3x times greater. In theory, this should allow these devices to retain 80% capacity over 3 years.That's more likely due to the build of the battery. Not all Li-ion have the same total cycles. I never trust the cycles quoted by the mfg.
Mainly this is due to old thinking, with the current battery technology as long as you run the battery below 10% once a month you should be fine....At work I'm using Dell's Power Management App, that let you choose when charge or not my XPS 13 battery when it's plugged. Currently my laptop automatically charges when battery drops below 50% and stops once 80% is achieved. I wonder why other manufacturers doesn't implement something similar.
Just to clarify, whenever the battery achieves the desired charge (80% in my case), it not only stops charging but use only AC, so battery does not used/drain.This app is only available in some (high) Dell laptops. Mine is i7 version, a friend of mine had the i3 one and don't have it. Maybe is something related to bios version. IMHO is something useful when you plan to use a laptop as desktop PC. This avoid to overcharge your battery or, at at least, avoid mini cycles (xx to 100% then 98-99%, 100% again, and so on) like Apple does with iPhones and iPads.
How it works?All modern power management schemes are capable of preventing over-charging of batteries when plugged in, if the OEM has not implemented the technology and require the use of an utility that is worrisome. Microsoft has actually implemented it via the Power Management and Cooling Firmware.
The Firmware prevents the continued charging of the battery when plugged in and when the Battery reaches 100%, AC Only. I posted the Surface Engineering Team's best practice a few posts ago.How it works?
What the Dell's app automatically do is the same some people do when you use a laptop as a desktop PC... Manually remove the battery before docking it... Something you can't do on a ultrabook like the XPS 13 or a tabletPC like the Surface Pro.
