Arizona Willie
Well with Chrome it worked just fine and told me I had the latest version.
Verified Java Version
Congratulations!
You have the recommended Java installed (Version 7 Update 17).
With IE not so good. Kept telling me it only worked in the desktop version with Windows 8 and I was using the desktop version of IE.
I have gone into the Java Control Panel and verified that Javascript was turned on.
As for the site where I get the java message here is a copy of a screen shot. You can see the small popup at the bottom too.
I don't know why java would even be involved to just bring up another link but apparently it is.
Also I can't sign in to the Microsoft help site because apparently it uses java in the log-in. grrrr
Of course, I can go there with Chrome -- no problem.
I have gone into Manage add-ons and disabled every single one I can find and i still get the popup telling me an addon for this site didn't run.
Then I went back and re-enabled every one of them and still go the message that a popup for the site didn't run == but of course the popup doesn't bother to tell you WHICH ONE.
And to further mystify me, why do I only get this big black screen with the java message and popup on the one site. The failed log-in on Microsoft doesn't give me any message so it may not be connected. But this all started at the same time. One day all was well. Next morning big problems.
