Is 10Gb networking possible?
lifespeed
SPro7
I know, dumb question. Despite the high potential data rate of USB-C 3.2, I would guess there is no way I can make use of the 10Gbit fiber connection that runs to the desktop I'm replacing with this SPro7? I think I can get a USB-C to SFP+ network adapter. I have network-attached storage, so the 10Gb fiber makes it responsive.
I have a Surface Dock 2 on the way. Does the magnetic connector actually support 10Gbps USB-C 3.2? Probably this is one thing the desktop could do the SPro7 can't.
AFAIK there aren't any 10gb USB ethernet adapters and if there was they likely would not get 10gb but maybe 6-8gb at best due to overhead and internal system priorities over the USB channel. There are a couple 5gb USB adapters you could maybe team them through a switch. That's probably the best you'll do. I'd expect the same limitations with USB-C to fiber because USB 3x is where the bottleneck is. I saw a couple of SFP+ adapters with USB-C connectors but they all were Thunderbolt3.
The Surface Dock 2 USB-C ports do support 10gbs USB 3.2 Gen2
Know of any 10gbs adapters/dongles that work w the Dock 2 USB-C ports?
