No videos, but....there is a little black wire rectangle about 1/4 inch wide and as long at the keyboard is wide. You simply slide the part of the keyboard that attaches to the surface through the wire rectangle, then snap the wire down into little slots into the folio cover. It holds the keyboard in the folio very snug. You can attach your surface to the keyboard and remove it as you like. Personally, I used the folio for a few months, but nowI use nothing but the surface and attached keyboard only. I found the folio was not necessary for me. I hope this helps.
