HowTo How To and Master Help for the Surface Pro 4
Status
Not open for further replies.
Wake Up From Sleep
If your Surface is in sleep mode and won't wake up (screen black, keyboard Caps shift lights up but no wake), try this:
Press power button for 1 second. Release. Repeat.
How to lessen the Edge crashes and make your browsing smoother.
Useing the HOST File method of Ad Blocking with a slight change to the Registry and now Edge works very fast with no Display Crashes on HTML5 Video Ads (like this site).
http://winhelp2002.mvps.org/hosts.zip
Once you download that file, extract it anywhere and go into the folder and run mvps.bat as administrator. This will install the hosts file mod and now all known ads and malicious sites will be blocked from your PC. However, there is another step to ensure smooth performance with DNS resolution, as large HOSTS files tend to cause issues with the default settings.
To apply this tweak you need to do the following:
  1. Open Regedit
  2. Navigate to HKLM\SYSTEM\CurrentControlSet\Services\DnsCache\Parameters
  3. Create a new DWORD “MaxCacheTtl” and set the value to 1
  4. Create a new DWORD “MaxNegativeCacheTtl” and set the value to 0
  5. Reboot your PC
Once you have done the above, you will have an effective ad blocking solution that will work across your entire system (including Microsoft’s new browser), and with the added tweak there will not be any performance hit in your browsing experience. Without the added tweak you would notice site loading delays, especially with sites like Hulu etc…
Source: Blocking Ads with Microsoft Edge (Project Spartan) | Chris123NT's Blog
Credit jnjroach
Fix Maps App not showing roads
Microsoft fix for Default Maps App not showing roads.
(Fix applies to NVIDIA processors. Start, NVidia)
Before:
After:
Save yourself some trouble, and perhaps your files, too by enabling Restore Points on your device. This will allow you to revert to how your system was configured before adding software or drivers or changing settings. I create restore points every now and again when all is well.
Former users of Windows 7, Windows XP, Windows Me will probably be happy that Windows 10 also provides this functionality.
Search for "Restore Point".
To relocate OneDrive files to a different drive or folder (SD card, etc.):
1) Unlink OneDrive. (Find the Notification Area OneDrive icon, right-click, Settings, Account Tab, Unlink)
2) Exit OneDrive. Verify it is stopped (Find the Notification Area OneDrive icon, right-click, Exit)
3) Copy and paste your OneDrive folder to the destination.
4) Reboot. Start OneDrive (Search, OneDrive). Direct OneDrive to the new location.
OneDrive can take hours to verify that all of your files match the Cloud. It is best to keep a stable and fast Internet connection during the process, because the verification begins again from the start if your connection is broken. You are finished when OneDrive reports "Up to date." in the notification area.
Only after OneDrive reports "Up to date" should you delete files from the original location.
Settings that can have shortcuts on the desktop:
Code:
Account Info: ms-settings:privacy-accountinfo
Airplane Mode: ms-settings:network-airplanemode
Backgrounds: ms-settings:personalization-background
Battery Saver: ms-settings:batterysaver
Bluetooth: ms-settings:bluetooth
Calendar: ms-settings:privacy-calendar
Camera: ms-settings:privacy-webcam
Cellular: ms-settings:network-cellular
Closed Captioning: ms-settings:easeofaccess-closedcaptioning
Colors: ms-settings:personalization-colors
Connected Devices: ms-settings:connecteddevices
Contacts: ms-settings:privacy-contacts
Data Usage: ms-settings:datausage
Date and Time: ms-settings:dateandtime
Dial-Up: ms-settings:network-dialup
DirectAccess: ms-settings:network-directaccess
Display: ms-settings:display
Display: ms-settings:screenrotation
Ethernet: ms-settings:network-ethernet
Family & Other Users: ms-settings:otherusers
Feedback: ms-settings:privacy-feedback
For Developers: ms-settings:developers
High Contrast: ms-settings:easeofaccess-highcontrast
Keyboard: ms-settings:easeofaccess-keyboard
Lock screen: ms-settings:lockscreen
Magnifier: ms-settings:easeofaccess-magnifier
Manage Wi-Fi Settings: ms-settings:network-wifisettings
Messaging: ms-settings:privacy-messaging
Microphone: ms-settings:privacy-microphone
Mobile Hotspot: ms-settings:network-mobilehotspot
Motion: ms-settings:privacy-motion
Mouse & Touchpad: ms-settings:mousetouchpad
Mouse: ms-settings:easeofaccess-mouse
Narrator: ms-settings:easeofaccess-narrator
Notifications & Actions: ms-settings:notifications
Offline maps: ms-settings:maps
Optional Features: ms-settings:optionalfeatures
Other Devices: ms-settings:privacy-customdevices
Other options (Ease of Access): ms-settings:easeofaccess-otheroptions
Personalization: ms-settings:personalization
Power & Sleep: ms-settings:powersleep
Privacy: ms-settings:privacy
Proximity: ms-settings:proximity
Proxy: ms-settings:network-proxy
Radios: ms-settings:privacy-radios
Region & Language: ms-settings:regionlanguage
Sign-In Options: ms-settings:signinoptions
Speech, Inking, & Typing: ms-settings:privacy-speechtyping
Speech: ms-settings:speech
Start: ms-settings:personalization-start
Storage Sense: ms-settings:storagesense
Tablet Mode: ms-settings:tabletmode
Themes: ms-settings:themes
Typing: ms-settings:typing
VPN: ms-settings:network-vpn
Wi-Fi: ms-settings:network-wifi
Windows Update: ms-settings:windowsupdate
Work Access: ms-settings:workplace
Right click an empty space on the desktop, select NEW - SHORTCUT
Type in the setting identifier in the location box, assign a name, and you are good to go.
Enable GodMode for a complete "list" of all the setting available. This can be done by creating a folder on the drive or on the desktop and name it
GodMode.{ED7BA470-8E54-465E-825C-99712043E01C}
Status
