HowTo How To and Master Help for the Surface Pro 4
Status
Not open for further replies.
sharpuser
Administrator
Eastern USA
SurfaceBook2
Need help with your Microsoft Surface Pro 4? This is a good place to start.
The Staff of SurfaceForums.net provide this thread as a compilation of how-to guides, fixes, help tutorials and tips which have solved problems or saved time.
SURFACE KEYBOARD SHORTCUTS
Print Screen (Screen image to Clipboard for Paste elsewhere)
Fn + SPACEBAR
Screenshot (Saved in Pictures folder)
Fn + WINDOWS KEY + SPACEBAR (in this order)
Print Current Window Only
Fn + ALT+ SPACEBAR
Screen Brightness
Fn + DEL = Screen Brightness UP
Fn + BACKSPACE = Screen Brightness DOWN
Lock or Unlock Fn
Fn + Caps Lock
Home
Fn + Arrow Left
End
Fn + Arrow Right
PgUp
Fn + Arrow Up
PgDown
Fn + Arrow Down
UPGRADING YOUR EQUIPMENT
SAVE TIME AND TROUBLE TRANSFERRING YOUR ONEDRIVE FILES
If you are upgrading to a Surface Pro 4 from another Surface Pro 4, or any other PC under Windows 8 or Windows 10, your Microsoft Account will be able to sync many of your settings automatically. But OneDrive files should be transferred before you do various updates on your new computer. Many Microsoft updates will halt until OneDrive completes. So, here is a tip that could save you hours of time, and perhaps also save you from losing some precious files:
1) Copy your entire OneDrive folder from the previous PC to removable media, such as a portable hard drive, a USB drive, an SD media card, or the like. You can usually drag and drop the entire OneDrive folder from your PC to the removable media by using File Explorer. You may have 10 or 50 or even 100 GB of data, so it may take 30 minutes or so to complete the task.
2) After signing onto your new computer with all your Account credentials (Settings, Account), exit OneDrive. You will find its icon on the lower right of your desktop, or if you don't see it there, click the "^" icon you see in that area. The OneDrive icon is usually shaped like a cloud. Right-click and choose Exit.
3) Connect the removable media from step 1) above to your new computer. Open the OneDrive folder on that media. Copy ever folder there to your new OneDrive folder on your new computer. You can usually drag and drop. You may have 10 or 50 or even 100 GB of data, so it may take 30 minutes or so to complete the task.
4) Start OneDrive, by clicking once on the cloud-shaped icon you found in step 2) above. OneDrive will then make sure the files stored on the cloud (somewhere out there) matches your set. You may then proceed with setting up your new computer.
If you wish to uninstall Windows Store apps many will uninstall when you right click on them in the start menu. The problem is, they will come back during the next app updates from the Store.
In order to truly uninstall an app, use the following as a guide. This will even uninstall apps that don't provide that option in the start menu, such as the XBOX app.
Open powershell as administrator
Get-AppxPackage *3d* | Remove-AppxPackage
Get-AppxPackage *xbox* | Remove-AppxPackage
Get-AppxPackage *bing* | Remove-AppxPackage
Get-AppxPackage *zune* | Remove-AppxPackage
Get-AppxPackage *photo* | Remove-AppxPackage
Get-AppxPackage *communi* | Remove-AppxPackage
Get-AppxPackage *solit* | Remove-AppxPackage
Get-AppxPackage *phone* | Remove-AppxPackage
Get-AppxPackage *soundrec* | Remove-AppxPackage
Get-AppxPackage *camera* | Remove-AppxPackage
Get-AppxPackage *people* | Remove-AppxPackage
Get-AppxPackage *maps* | Remove-AppxPackage
USING THE PEN WITH YOUR SURFACE PRO 4
The Surface Pen (4) provided with the Surface Pro 4 and Surface Book differs from the Surface Pro 3 pen in
several ways: The pen writing nub is different, the pen is pressure-sensitive, buttons placement and purpose are reconfigured, and the pen is magnetic, for attaching to your screen.
If your pen is not paired to your computer, or not all the functions work, read below "Connect the Pen"
Customize pen buttons:
Launch the "Surface" app to customize use of the pen buttons.
Launch multiple items with a single Pen button:
HowTo - Launch multiple Apps and Programs with single Pen button | Microsoft Surface Forums
DEFAULT PEN BUTTON FUNCTIONS:
Top "eraser" button:
- One click opens OneNote, allowing writing immediately.
- Two rapid clicks (double-click) takes a screenshot. The screenshot is stored in the Screenshots folder (default location is C:\User\[account]\Documents\Screenshots, but the pen can be used immediately to crop out a particular area of the screenshot.
- Click and hold to start a Windows search, hosted by Cortana.
- Bring the "eraser" button to the screen to undo, or "erase" your writing. In some applications, the eraser button can also be used to draw, though this may be a bit clumsy.
Side "right-click" button is located near the writing tip of the pen, on its flat edge:
- Hold the button and touch the screen for a right-click. This is the same action as touching the screen with your finger and holding.
Battery Indicator
- A single AAAA battery powers the pen. A tiny LED is located around the pen opposite the pen clip. If it glows red, your battery needs changing. You may want to keep a couple of spare AAAA batteries in your computer travel case.
Pen sensitivity can be adjusted by opening the free Surface App from the Microsoft Store . If you apply any kind of physical glass or plastic screen saver to your screen, you will certainly want to do this. For most people, the default sensitivity is just fine.
Get started:
To try out writing with your pen immediately, you might
- Give the "eraser" a single click, and begin writing into OneNote.
- From Edge Browser, click the icon of a pen in the upper-right (or tap it with your finger). Begin writing with the pen.
Connect the pen:
Of course, if your pen is not paired to your device, it must be set up.
1) Settings, Devices, Bluetooth
2) Turn Bluetooth on.
3) Hold the "eraser" button of the pen for seven seconds until an LED glows white.
4) Click Pair
If the pen shows as already paired, but is not working, select that item, and click Remove device. Then start from Step 3.
If you cannot get the pen to Show by name ready to pair in Bluetooth Devices:
Uninstall the pen device driver, and allow Windows to re-install. Updated drivers are also available here. Windows may not show the pen to be available when connecting the Surface Pen 4 to a Surface Pro 3 which previously had the Surface Pro 3 pen.
1) Start, type Device Manager
2) Find Human Interface Devices, Surface Pen Settings, and Uninstall the driver. Do not remove the driver, however. Immediately re-try to connect the pen, according to the instructions above.
Use a pen previously paired to a Surface
If the pen is already paired to another Surface device within range (less than 10m (33 feet) feet or so), you must either un-pair (remove) the pen from the Bluetooth list of that device, or power the device down. A single pen cannot be paired to two devices.
Battery usage and reports
Battery status reports on devices like Surface can be very informative. It's possible to tell a lot bout what may be consuming battery and its general health. This is a primer on the basics. (most if not all of these commands will work equally well on Windows 8.1 or Windows 10. Your report formats may vary)
PowerCfg should be run at an admin command prompt. Type cmd in search, right click on CMD and click run as administrator. All reports can be found in the \Windows\system32 folder by default in the forum of an HTML file.
Available Commands:
PowerCfg /energy
PowerCfg /batteryreport
PowerCfg /sleepstudy
Energy
will show what is generally consuming the most battery. It's an efficiency/diagnostics report
Batteryreport
will provide the following information.
  • Basic computer inventory
  • Installed battery information
  • Power states over the previous 3 days
  • Battery drains over the previous 3 days
  • History of system usage on AC and on battery
  • Charge capacity history of the system's batteries
  • Battery life estimates based on observed drains
Sleepstudy is a great way to find out what is running while the Surface is sleeping in Connected Standby.
[edit]
More commands that may be useful
/LASTWAKE Reports information about what woke the system from the last sleep transition.
Hard reset
If you are having problems that you can't quite figure out, with some type of connectivity, such as getting an external monitor working try this.
After your Surface turns off, press and hold the volume-up button and the power button at the same time for at least 15 seconds, and then release both. The screen may flash the Surface logo or just flash, but continue holding the buttons down for at least 15 seconds.
After you release the buttons, wait 10 seconds. Then press and release the power button again to turn your Surface back on.
Status
