debpolaris
- Joined
- Apr 18, 2017
- Messages
- 1
- Points
- 1
- My Device
- SPro3
Hello~!
I recently bought old medical monitor, WIDE IF2103M which has DVI-d 1536x2048(QXGA) resolution grey scale monitor.
To connect, I also purchased DVI dual link cable(support max resolution 2560x1600 WQXGA) and mini dp to dvi-d active adapter(also support max resolution 2560x1600 WQXGA).
mini dp to dvi-d active adapter : Amazon.com: Monoprice Mini DisplayPort/Thunderbolt Plus USB To Dual-Link DVI Adaptor (106904): Computers & Accessories
WIDE IF2103M : 3MP Grayscale WIDE IF-2103M LCD (Refurbished)
The problem is that my screen display is split in two.
I upgraded new intel graphic driver to solve this problem but failed.
Also I do not set any screen resolution any more...
It fix 1536x1024 resolution.
It is very confusing now.
