ctitanic
SP3 does not hibernate after 4 hours of sleep (http://support2.microsoft.com/kb/2998588/en-us )
Try Hyper for YouTube; I use it all the time.Whats a good MUI Youtube app? I would use one that one if it looked and acted like the webpage...
Have you tried a refresh? It should be displaying the amount of energy for each of the specified times.i think my battery is borked ? i don't see any mW values. is this a known bug ?
Its your choice of Video Player, VLC (and most Win32 Programs) are battery hogs, Universal Apps impact battery far less then traditional Windows Applications.I got a SP3 i5 258gb 8gb and i cant seem to get over 5 hours of use. It has got 53 charge cycles now and charge capacity of 40,782 mWh.
I get at max 5 hours watching videos on VLC that are 720p at lowest brightness.
Is this normal performance?
Ive seen people who reviewd saying they can get 7.5 hours with brightness 100% and over 8.5 hours of video with brightness at lowest.
Should i try and reset and reinstall everything?
Using the Modern UI IE will vastly improve your battery life....Thanks for reply
The choice of vlc was because of the file format. It's .mkv and and the player on windows 8 that can play this, only plays in full screen so it doesn't allow me to do other things while video is playing.
I was also using Firefox browser and I ram from 100% battery to about 90% in like 20 minutes.
I was able to run maximum 5 hours 20 mins brwowing Internet. Is this also because I'm not the IE? Would I get better battery life using EI?
Also with no apps open and CPU utilisation fluctuates from 1% to 8%, is that normal?
Last summer I flew to Europe and I watched 4 movies for a total of 6 hours and listen to music for 2 hours, when I landed I had 20% battery life, flight was 9.5 hours....How long are you guys getting of video watching? On downloaded movies/tv series and youtube?
Do a factory reset prior to assuming its a hardware issue. Also, change your media player, try Media Monkey or the VLC Universal App....Wow. So I'm getting 5 hours max, on 720p videos with brightness at lowest and not using anything else.
So would you say that there might be a problem with my battery? I'm trying to find out so that if I need to get in touch with support and Exchange my sp3 I'll do it sooner rather than later.
My cycle count on battery is 56 charges only.
