Frame not rigid enough
J5250P: THANK YOU ---- THANK YOU --- THANK YOU
That fixed the whole problem with the screen trying to flip orientations.
I had never seen that tip about the screen lock before.
That is WONDERFUL.
I almost always use my Pro in landscape mode so I will leave it locked unless I have an unusual session where I want it in portrait.
Willie, also try the lock screen rotation feature for when you are reading in bed. In the Charms bar (swiping from right edge in) Settings>Screen and at the top of the brightness scale there is a screen with arrows at the corner. Touch that and it will lock the screen in whatever orientation it is in at that time. Then no matter how you tilt or twist the screen it will stay in the same orientation.
Thanks Russ. I have a start button app installed on my Pro and when I touch that White Windows Icon it switches back and forth from desktop to metro interface. Doesn't bring up the start menu.
But it is very handy for changing interfaces.
So many little un-documented little tricks. :)
