Flash No Longer Working on RT After IE11/Flash Updates
Update: Problem solved.
Steps: Refresh, reinstall all windows updates ==> Flash no longer being a whiny b****.
I guess the take home lesson is if you notice something is wonky and think it's due to a particular patch, try to locate the specific update, remove It, and reinstall. If that fails, try Refreshing and just reapplying all updates.
Did you get your problem fixed Sepp?
Thanks Dude,
I already removed this known flash update, but unfortunatelly it did not work for me.
Now I need to do a complete refresh :(
BR
