Finding the Battery Drain
I charged up my SP3 this AM to 100%. Closed lid, headed out at 8:30am.
6.5 hours later, I started my SP3 back up and battery was down to 66%!!!!
Prior to my Windows 10 install, the worst I have dropped was between 5-6%.
Any suggestions or ideas? The machine was sleeping and I did have Cortana activated so I'm wondering if this could be the reason?
Part of the issue is I have no way, that I know of anyway, to tell what was the culprit... my iPhone will tell me what is using the most battery. My Samsung Note would do the same. But not this?
If you're not going to use your computer for over 6 hours, I wonder what would happen if you just leave it powered off or power it off during those 6 some hours.
I was having the same problem - and I am now testing whether the problem continues after having done the following: (1) I removed the mSD card; (2) I then put it back in; (3) From Device Manager, under Drives, I went to SD Card> Properties and reinstalled the driver.
For the moment my SP3 is quiet and cool. Also, I am testing the effect of this on the battery. Let's see what happens!
It worked for sometime but the SP3 - after a shutdown and a restart - started its fans and the warming up thing again!
