Hi,
I've been trying for quite a while to digitize some old cassette tapes using my SP3 and Audacity. I have several problems. First, the cassette deck I'm using only has headphones out. I'm using a 3.5 mm to 3.5 mm cable. So, I have an adapter that takes converts that headphone jack to 3.5 mm. I then plug the other end into my SP3 and try to record from the deck. I've tried every recording option (headset microphone, microphone array, stereo mix) and every playback option (speakers, headphones) in every combination and still can't monitor the recording - therefore, I can't record because I can't set the proper levels and I'm unsure the sound card can record anything. I can hear the tape if I use the converter and headphones...any suggestions??
MShepp
MShepp
