Hey guys,
For about a week now i've been the proud owner of a sp3 i5 256 gb's of ram. I've been loving it so far, and its incredibly fast.
There are some problems however. When the system stays idle for a while it locks itself (brings up the lock screen). 4 out of 5 times when this happens, a couple of seconds later it will restart itself. Theres an error in the logs about the previous shutdown happening unexpectedly.
Besides that, i have gotten bsod's at various moments and with various error messages. It happened once while installing updates. A couple of times after unlocking the device, and then just some random moments.
critical structure corruption it said once, and some other time it was about irql, then once memory related..
Has anyone else been getting this? Do you think hardware is at fault or should I do a full reset.
I havent installed anything weird really, heres a list:
- Chrome browser
- Netbeans
- Java
- filezilla
- dropbox
and then a bunch of windows store apps
Edit:
From time to time theres also an error in the logs about the local bluetooth adapter not working properly and the driver being removed.
- Chrome browser
- Netbeans
- Java
- filezilla
- dropbox
Edit:
