Best Solution To Connect Two 2560X1440 Displays To A Surface 3
what about this:
http://www.club-3d.com/index.php/products/reader.en/product/mst-hub-1-3.html
add another converter
http://www.bhphotovideo.com/c/produ...DP_2_DPF_Mini_DisplayPort_to_DisplayPort.html
but it sounds like the dock will work for you, see third bullet.
  • 3 USB 3.0 ports, 2 USB 2.0 ports, Gigabit Ethernet port, 3.5mm audio input/output connection, Mini DisplayPort
  • Security lock slot
  • Innovative design leaves the Mini DisplayPort and USB 3.0 port on your device available for use when docked
Ok. To summarize it sounds like using a hub is the best path and ideally I will wait for the 2port hub.
Is anyone running a setup like this. Would be interest in hearing success with this setup. Specifically this displayport hubs
