Authorized Customer
Recently, my Surface Pro 3 has stopped charging to 100%.
For example, last night, I powered it off (used Shut Down from the Start Menu, not simply closing the keyboard case or putting it in sleep mode) and left it on the charger for 9 hours. It was at 90% this morning when I booted it up while still on the charger. No, we did not lose power last night.
This morning, I powered it on and put it back on the charger. It's currently at 94% and indicates that it's stopped charging:
The same thing happens when it's in the Surface dock at work, which has its own charger.
When the device was new, I recall routinely seeing 100% after a good charging time.
The only recent change was a clean install of Windows 10, as in wiping the device and installing Windows 10 from the ISO. Since the problem happens even when it's shut down (i.e., no OS running even in connected standby mode), I don't think it's OS-related.
I am used to other PCs that do have a small range near 100% where charging will stop but pick back up when it falls below a certain threshold, like a kludgey trickle charge mode. Those happen in a much smaller band than 10%!
Sometimes I need every last bit of power from this device, and starting with 10% depleted is not good.
