Yes, it can be plugged in at any point and as long as you discharge below 10% at once a month you're good....1)S can I plug it or is it not good for the battery ?Because I don't want that the battery makes 99 after 100% of charge/discharge. Do you see what I would like to say ?
If plugged in you are not using battery....2) When I'm plug, there is just "plug, in charge" or "charged" but nothing which is say that I'm not using the battery but the power supply. Moreover when I'm full charged I can heard the loader...
Yes
