Battery Limit is Enabled on Surface Book 2 but only works for battery 1??
scoob101
Surface Book
Same behavior on my Surface Book 2:
Battery 1 (Small capacity, screen, "Clipboard") does not use the battery saver function.
Battery 2 (Large capacity, keyboard, "Base") uses the battery saver function, with adjustable % remaining before power limiting begins.
How are you able to adjust the %remaining value?
Settings, System, Battery
Battery Saver is different from Battery Limit.
BS limits power usage when your battery gets low.
BL prevents the battery from charging fully if you have the SB plugged in for a long time (was named kiosk mode in some models).
