VickiFL
Just make sure you ask someone who is technically qualified and you will of course get the right answer!
Regards
Chris
I get different answers from everyone!
Regards
Chris
Ask 10 Battery Engineers and you'll get 12 different answersI get different answers from everyone!
And heres mine (sorry I just copy-pasted it, too lazy to take a screenshot)
I drained my SP3 battery today. Started at 100% and drained down to 5%. I had screen brightness at 50%, and only surfed the web. I also had Pandora going via browser (Google Chrome), not app. I got a little over 6 hours of battery time. I need to repeat this experiment using IE. (btw, I am using my SP3 in desktop mode for this experiment because that's how I use my SP3 95% of the time)
You are comparing an arm device to an Intel device?I hate Apple but I have an ipad 2 (work) that is used daily that was bought on opening day that is still used daily with IOS 8.1.1 and while it's lagging today the battery will still last a week without charge. This is how devices should work, not running multi-line commands to generate html files of battery stats. Come on now....
When I was using my iPad2 daily on the web it didn't last all day without needing a charge but yes, if you don't use it that much then the battery will last longer.I hate Apple but I have an ipad 2 (work) that is used daily that was bought on opening day that is still used daily with IOS 8.1.1 and while it's lagging today the battery will still last a week without charge. This is how devices should work, not running multi-line commands to generate html files of battery stats. Come on now....
I get roughly the same runtime WITH music (20%), video (20%), and apps (15%), but mostly browsing (40%), but no Chrome. In case you didn't know, Chrome is one of the biggest battery power drain culprit.I used Chrome all day, and got 7 hours and 15 minutes. That makes me happy.
That test was done with no music, video or apps, and 50% screen brightness.
Maybe I'm getting more because I am working the battery.
Hence, I think you could get better runtime than that, if you didn't use Chrome.
