Hmm, last post on this was Feb 2013 ... he probably just wrote his own driver by now.Ummm, hate to state the obvious, BUT, had you gone to the "Windows Update" section within Control Panel (not the useless PC Settings section) then used "Check for Updates" and selected just the wifi drivers to install, you would have been set in 1/10th the time.
You should let it install all the important ones, but that can take a few hours, so selecting what you need gets you started until you can leave it running to update everything.
You do have "Check for updates but don't download them" set??![]()
I think threads should be locked after some period of inactivity or at lest warn you ... hey your posting to a thread with no activity in xxx days are you sure you want to proceed ...
